Previous Topic: VOX6128Next Topic: VOX6150E
VOX6129
This message generates either of the following:
Program-name instance-number item-number EXEC RETURNED RC=0
Reason:
The Notification Manager program Program-name ended with a return code of 0.
Action:
None.
Program-name instance-number item-number EXEC RETURNED RC=rc ERROR= error-text
Reason:
The Notification Manager program Program-name ended with return code rc and error message error-text.
Action:
Look up the return code and error message and follow the provided instructions. If you still cannot determine the cause of the error or are unable to correct it, contact CA Technical Support.
