Previous Topic: VOX6106Next Topic: VOX6122
VOX6121
Message numbers 6121-6129 are configurable messages that Notification Manager sends to the console. These messages contain the following variables:
item-number
Each time you issue a notification request, the request is assigned a unique four-digit number. This number allows you to track the progress of a particular notification request.
Note: The first few messages from the NMFIND.REX program do not have a unique four-digit number (the item-number is reported as “0000” because a number has not yet been assigned).
instance-number
Each time a Notification Manager REXX program runs, it is assigned a unique number based on its start time and date. This number enables you to differentiate between multiple copies of a particular Notification Manager REXX program that are running at the same time or for the same item.
This message generates any of the following:
Program-name instance-number item-number Called-rexx call-parms: RC= rc ERROR= error-text
Reason:
The Notification Manager program Program-name called the REXX program Called-rexx with parameters call-parms, and it received return code rc and error message error-text.
Action:
See the description for the message, xxxnnnny, where xxx is any message prefix, nnnn is the return code, and y is the message suffix. Follow the provided instructions.
Program-name instance-number item-number Called-program-name call-parms: RC= rc
Reason:
The Notification Manager program Program-name called the non-REXX program Called-program-name with parameters call-parms, and it received return code rc.
Action:
Program-name instance-number item-number FAILUREREXX PROGRAM (FailureRexx-name) RETURNED RC= rc
Reason:
The Notification Manager program Program-name called the Failure REXX program specified on the NMFIND call, and it received return code rc.
Action:
