Previous Topic: VOX6088ENext Topic: VOX6091E
VOX6090E
This message generates either of the following:
The KEY parameter was not specified properly.
Reason:
Keys have valid ranges. An entity key must be between 100000000 and 199999999. A method key must be between 200000000 and 299999999. A parm key must be between 300000000 and 399999999. A time key must be between 400000000 and 499999999. A login key must be between 800000000 and 899999999. The key you specified did not meet this criteria.
Action:
Specify a valid key.
The xx key is unspecified.
Reason:
You forgot to specify the value of a required key.
Action:
Specify the value.
