Reason:
Keys have valid ranges. An entity key must be between 100000000 and 199999999. A method key must be between 200000000 and 299999999. A parm key must be between 300000000 and 399999999. A time key must be between 400000000 and 499999999. A login key must be between 800000000 and 899999999. The value you specified met this criteria, but it did not exist in the database.
Action:
Use the appropriate List command (ListEntity, ListParm, ListTime or ListMethod) with the NAME(*) parameter to find the item you are looking for.
Copyright © 2012 CA.
