Reason:
This message is used to signal the end of a batch paging cycle for the paging service specified by the tonestring phone number. The batchid is a sequential number used to identify the batch cycle. The rc is the return code for the entire batch cycle. If this return code is zero, all of the submitted page requests (successful or not) have been properly processed by the paging service. If this return code is non-zero, the paging service encountered a problem when processing one or more page requests contained within this batch that were previously reported as successful. This could mean that a page request previously reported by the paging service as successful has, in fact, failed due to the content of the message.
Action:
If the return code is non-zero, consider resending all the page requests contained in the current batch to ensure that each message is sent at least once, since the TAP protocol does not identify which message contained within the batch failed. You can find out which page requests were contained in the current batch by looking for the VOX5507I and VOX5508E messages that reference the same batchid value. You may also want to contact your paging service provider to determine the reason for this condition (see the TAP protocol version 1.8, step 10b).
Copyright © 2012 CA.
