Reason:
The notification server was unable to connect to the specified two-way paging service to submit the two-way page request.
Action:
Ensure that TCP/IP is configured and functioning on the CA Automation Point server machine. If you are using the SNPP protocol, make sure both the host name and the TCP/IP port number of the paging service's SNPP Server are correct. If you are using the WCTP protocol, make sure the gateway URL, DTD URL, and paging service authentication information (if required) are correct.
Copyright © 2012 CA.
