Reason:
The requested VOX command is either not supported by the notification server, or the feature associated with this command is not enabled in Configuration Manager.
Action:
Ensure that the feature associated with the requested VOX command is enabled in Configuration Manager. If this does not resolve the problem, make sure both the client and server machines are running the same version of CA Automation Point software.
Copyright © 2012 CA.
