Previous Topic: TNG5920ENext Topic: TNG5922E
TNG5921E
No popup menu
Reason:
The CA NSM kernel received a “no popup menu” condition. CA Automation Point receives this return code from its low-level call to the CA NSM kernel.
Action:
CA Automation Point receives this return code from its low-level call to the CA NSM kernel. Ensure that the CA-AP NSM Gateway service is functioning correctly, that the CA NSM Common Object Repository functions outside of CA Automation Point (try creating an object or setting the attribute of an object from the CA NSM WorldView Map), and that the CA Automation Point class definitions have been correctly loaded into the Common Object Repository. If you have taken all the above actions and the problem still persists, contact CA Technical Support.
