Previous Topic: Message Format and FlowNext Topic: Message Flow
Message Format
All CA Automation Point messages have the following format:
Prefix  Return Information  Suffix  MessageText
Prefix
Indicates the component or environment that issued the message, limited to three characters:
AXC
ADDRESS AXC or session management
ADDRESS OPS or CA OPS/MVS to CA Automation Point Interface
VOX
ADDRESS VOX or notification services
PPQ
ADDRESS PPQ
ADDRESS GLV
TNG
ADDRESS TNG
Return Information
A four-digit number or the return code set by a command executed from any of the CA Automation Point ADDRESS command environments.
Suffix
Indicates the message type (one-character); most messages have one of the following suffixes:
I
Indicates Information about CA Automation Point requiring no response from you.
A
Indicates messages requiring you to respond by taking some action.
W
Indicates a Warning of non-critical errors.
E
Indicates an Error message, usually not recoverable. If it is possible to recover from the error, CA Automation Point asks you for more information.
F
Indicates a fatal error, not recoverable.
X
Indicates an internal error. This type of error occurs only in rare cases and usually requires that you contact CA Technical Support.
