Reason:
The TCP/IP socket associated with the native TN3270 or TN5250 session indicated by sessname has failed on a write request. The rc value is an internal failure return code.
Action:
Save the out.deb and other log files and contact CA Technical Support.
Reason:
Session "session-name" was configured with the auto-signon feature but the auto-signon failed with the reason detailed in the "reason-text" field.
Action:
Depending on the reason, you may need to modify your configuration or modify a setting on the host in order to get auto-signon to work properly.
Reason:
Session "session-name" was configured with device name but the connection to the host failed with a reason detailed in the "reason-text" field.
Action:
Depending on the reason, you may need to modify the device name or configure the device name on the host in order to get the connection to work properly with device name.
Copyright © 2012 CA.
