Previous Topic: AXC1307WNext Topic: AXC1351W
AXC1350W
Asynch: function Device: devicename Op: operation Msg(numcode): errortype
Reason:
CA Automation Point has experienced a serial communication error.
Action:
Check your asynchronous communication parameter file; verify proper settings for all parameters, especially CACHESIZE, PARITY, and BAUDRATE. Verify that the serial port is connected to the proper device. For example, you may have connected the port meant for the modem to your mouse. Note the values for function, devicename, operation, numcode, and errortype; contact CA Technical Support.
