Reason:
An I/O error occurred in the named session. Such errors can occur under normal circumstances. However, if you receive this message repeatedly, one of your asynchronous communication parameters is incorrect.
Action:
Modify the asynchronous communication parameter for this session. Use the error code returned to determine which statement is at fault:
If the error code is 16, check for an invalid Parity value.
Copyright © 2012 CA.
