Reason:
The REXX interpreter was unable to execute the specified REXX program.
Action:
Check the AXCREXX window for the error level, which indicates the reason for the failure, then contact CA Technical Support.
Note: Error level 204 indicates that the workstation is out of REXX resources. Check the value of Maximum REXX Program(s) in Configuration Manager and the amount of memory on the machine. Each additional concurrent REXX program requires a half megabyte of memory.
Copyright © 2012 CA.
