Previous Topic: AXC0771INext Topic: AXC0773I
AXC0772W
AXCREXX communications failure
Reason :
CA Automation Point is no longer able to communicate with the REXX language environment.
Action:
Check to see if any other applications (which use additional memory) are running with CA Automation Point. Lower the Maximum REXX Programs value. Reduce the number of sessions and windows. Add more memory to your workstation.
