Previous Topic: AXC0756INext Topic: AXC0763W, AXC0764W
AXC0757W
REXX share failure: out of memory
Reason:
REXX has run out of memory. You may see this message if the CA Automation Point GETSCRN or SESSCMD command processor returned a large amount of data.
Action:
Check the code returned by the GETSCRN or SESSCMD command processor to determine whether REXX has used up all the available memory. You may need to add more memory to your workstation.
