Reason:
CA Automation Point is not processing calls to its command processors, causing the product to display this message a maximum of once every 15 minutes. If you write a rule to launch a REXX program against a message ID that is displayed during CA Automation Point initialization, this message may appear. You can write rules to launch REXX programs against message IDs only after the “REXX command processor opened” message appears.
Action:
Verify that Enable AXCREXX is checked in the REXX Settings dialog. Also, make sure that REXX programs launched from rules are only on message IDs that occur after the “REXX command processor opened” message appears. If the problem persists, contact CA Technical Support.
Copyright © 2012 CA.
