Previous Topic: AXC0646WNext Topic: AXC0651W
AXC0647E, AXC0648E, AXC0649E, AXC0650
Attempting to add a key: newkey that is already defined: oldkey. To keep the new definition, the prior definition will be deleted. Keep the new definition (Y or N)?
Reason:
You are running the CA Automation Point keyboard utility program. You requested that CA Automation Point add a key that is already defined. The program displays both the new and the old definitions. If you want to keep the new definition, CA Automation Point will have to delete the old one.
Action:
If you want CA Automation Point to delete the current definition and replace it with this new definition, enter Y. If you want CA Automation Point to preserve the current definition, enter N.
