Previous Topic: AXC0638INext Topic: AXC0640W
AXC0639A
Enter shift:
Reason:
You are running the CA Automation Point keyboard utility program and are defining the SCAN instructions for an operation. CA Automation Point is waiting for you to specify a shift state (if any). The Administrator Guide describes the shift states in detail.
Action:
If this operation does not require any shift states to be true, press the Enter key. For example, a lowercase “a” requires you to press only the “A” key. If this operation requires a shift state, type the desired shift state, then press the Enter key. For example, an uppercase “A” requires you to press the “A” key and a Shift key or the Caps Lock key simultaneously. When you enter a value, the program prompts you again to enter a shift state. Enter another value or press Enter to continue.
