AXC Messages › AXC0622A
AXC0622A
K to keep, A to add, D to delete, M to modify, R to use defaults, Q to write file:
Reason:
You are running the CA Automation Point keyboard utility program, and you just pressed a key for which the indicated operations are defined.
Action:
Press one of the following keys:
- K to keep the current definitions (if any) for this key
- A to define one or more operations for this key
- D to delete all the current definitions
- M to delete one or more of the current definitions
- R to replace the current definitions with the default definitions
- Q to quit the program, saving any changes
Copyright © 2012 CA.
