Reason:
CA Automation Point found errors while trying to read the keyboard parameter file you specified in the Keyboard Mapping File field on the Automation Point Desktop Settings dialog in Configuration Manager. It will use a basic, built-in default keyboard mapping similar to the 88-key AT keyboard.
Action:
Correct the errors in your keyboard parameter file, then restart CA Automation Point.
For more information about the keyboard parameters, see the Command and Keyword Reference Guide .
Copyright © 2012 CA.
