Previous Topic: AXC0537INext Topic: AXC0539E
AXC0538W
nnnn REXX buffer messages for session sessname.
Reason:
The internal host-message-stream buffer (opened with the OPENBUF command for this asynchronous session) has collected nnnn unread messages.
This warning message appears for every 1,000 unread messages. If the number of unread messages in the buffer reaches 10,000, CA Automation Point discards any new incoming messages.
Action:
Check your REXX program to verify that it contains no logic errors that might be preventing the READBUF command from processing. Messages may be filling the buffer faster than your REXX program can process them. In such a case, you may have to use CA Automation Point rules to process the incoming messages in this session.
For more information about the OPENBUF, READBUF, and CLOSEBUF command processors, see the Command and Keyword Reference Guide.
