Reason:
You tried to open filename, but CA Automation Point cannot open the file for some undetermined reason.
Action:
When you want to view a file, be sure that you specify a valid file and that you spell its name correctly. If you did specify a correct file name and cannot determine why CA Automation Point cannot open the file, contact CA Technical Support.
Copyright © 2012 CA.
