Reason:
CA Automation Point cannot initialize a modem to which it is connected.
Action:
Verify that the initialization string you specified for the modem contains the appropriate commands. If the modem does not respond, verify that it is connected properly. If the connections are correct, contact CA Technical Support.
Copyright © 2012 CA.
