Reason:
CA Automation Point ran out of memory while executing rules, possibly because of a problem within a rule or because the rules file is too large.
Action:
Check for syntax errors in your rules. If you find no syntax errors but your rules file is very large, you may need to delete some rules or get more memory for your workstation. If something else caused the problem, contact CA Technical Support.
Copyright © 2012 CA.
