Reason:
Because no activity occurred on this session for the timeout period, CA Automation Point sent the restart string to the session. The timeout period (the default is five minutes) is specified using the Session Timeout, Interval field in the session definition set. The restart string is specified in the Session Timeout, Restart String field in the session definition set.
Action:
If you do not want CA Automation Point to check for communication activity, specify a value of zero in the Session Timeout, Interval field.
Copyright © 2012 CA.
