Previous Topic: AXC0216ENext Topic: AXC0218W
AXC0217W
Invalid Action Region Height for session sessname. Default value nn in use.
Reason:
In the session definition specified by sessname, you specified an invalid number of action messages in the Action Region Height field for session sessname. Instead of the value that you specified, CA Automation Point is using the default value (nn) appropriate for the terminal type that this session is using.
Action:
Modify the session definition, changing the value in the Action Region Height field for session sessname to a valid value. The terminal type specified for this session determines the valid values for the Action Region Height. For specific terminal types, see the help associated with the dialog.
