Previous Topic: AXC0210ENext Topic: AXC0212E
AXC0211E
Communications failure with session id name
Reason:
Host communications with the indicated CA Automation Point session have terminated. This message usually indicates some form of communication problem between the session and the host.
Action:
This situation is normal if the mainframe is being IPLed. If not, jump to the indicated session and look at the status line at the bottom of the screen. You may need to reset or power off this session before it is usable.
