Reason:
You have invoked CA Automation Point without enabling sessions or function windows in the active Session Definition Set in Configuration Manager or you have invoked CA Automation Point from the command line without a valid Session Definition Set name.
Action:
Stop CA Automation Point and exit by selecting the “Exit CA Automation Point completely” option from the Action menu. Configure a session definition set using Configuration Manager. To view any sessions on the desktop, you must define and enable that session. To view function windows on the desktop, you must enable the window, if already defined, otherwise, you must define and enable the window.
If you have only configured Notification Services, in order to see the messages generated by the notification server on the Automation Point desktop, you must enable the AP Notification Messages function window in the active session definition set.
Reason:
There is either no active session definition set configured or the session definition set file specified by this setting or as command line parameter is missing.
Action:
Identify the active session definition set using Configuration manager and confirm that corresponding file exists.
Copyright © 2012 CA.
