This section describes the keywords that you need to define when setting up script files. For details about setting up these kinds of files, see "Customizing Special CA Automation Point Files" in the Administrator Guide.
Use the following keywords to set up script files:
Terminates the preceding SEARCH.
Specifies what happens if a search fails.
Sends a keystroke string to the target session.
Searches the entire screen for a string of data.
Causes the script to wait for the preceding keystroke string to be accepted by the system.
Sends a single CA Automation Point operation instruction to a host session, regardless of whether the keyboard is locked.
Copyright © 2011 CA.
