Specifies the number of seconds that the e-mail request is to delay the processing of subsequent actions in the call tree.
Default: 60
Specifies the e-mail recipient names that are to receive a carbon copy of this e-mail.
Default: There is no default.
Determines whether Notification Manager is to generate debugging messages at the command prompt or the AXCREXX window and in the ASOTRACE log.
Default: NO
Specifies the number of times the e-mail request is to be retried if it does not go through.
Default: 4
Specifies the number of seconds that Notification Manager is to wait before trying to send an e-mail request again.
Default: 60
Specifies the maximum length of an e-mail recipient list (either the TO or CC list), including the separators.
Default: 1000
Specifies the maximum length of a message that the e-mail system supports.
Default: 30000
Specifies the maximum length of a Signature text string (Mail ID).
Default: 40
Specifies the maximum length of a Subject text string.
Default: 240
Specifies the number of seconds that Notification Manager allows the person who received the e-mail to call-in and handle the item before the FAILURE command is executed.
Database Default: 300
Internal Default: 900
Specifies the optional user-defined text that identifies or tracks the e-mail message.
Default: Notification Manager Automated Response
Specifies the Subject line of the generated e-mail message. The Notification Manager adds a prefix of "NM: " to the generated e-mail subject line and an additional prefix of "Callback Item XXXX", if the ASK operand is specified.
Internal Default: Notification Manager TELL setting
Specifies the name of the system that is to handle all notification server requests.
Internal Default: The local system name
Determines whether the TELL text from the NMFIND command is to be written to the e-mail verbatim. Values are:
The TELL text is written to the e-mail verbatim.
Allows Notification Manager to add a call-in number and item number to the TELL text.
Specifies the e-mail recipient names that are to receive this message. If more than one name is specified, these names must be separated by a semicolon (;).
Copyright © 2011 CA.
