Use the following keywords to define automation criteria.
Defines the beginning of a command rule (which activates when the specified command is issued).
Specifies how often you want an action to be taken.
Specifies how many times a CA Automation Point rule can execute in a given minute.
Limits the number of times that an action specified by a rule takes effect.
Defines the beginning of a message rule (which activates when a message having the specified ID appears).
Defines the start of a time rule (which activates at a certain time or after a specified time period has passed).
Defines additional conditions that must be true for a rule to activate.
Copyright © 2011 CA.
