CA Automation Point Keywords › Script Keyword Descriptions › ENDSEARCH Keyword
ENDSEARCH Keyword
The ENDSEARCH keyword terminates a search initiated by a SEARCH keyword.
This keyword has the following format:
ENDSEARCH
Example:
When an MCS console is active and operating correctly, it displays a message similar to one of these:
IEE152 ENTER CANCEL D C,K
IEE612I CN=05 DEVNUM=B4C SYS=S028 CMDSYS=S028
Suppose that your script contains these statements:
ERROR=IGNORE
SEARCH=(IEE152I)
KEY=(K S,DEL=N,SEG=20,MFORM=(T,J)@E)
ENDSEARCH
SEARCH=(IEE612I)
ENDSEARCH
The statements take the following actions:
- The first SEARCH statement tells CA Automation Point to search for the IEE152I message.
- If the first SEARCH statement finds message IEE152I, the KEY statement executes, putting the console in nondelete mode, setting the segment length to 20 lines, and so on; if the SEARCH operation does not locate the IEE152I string, the ERROR statement tells CA Automation Point to continue processing.
- The ENDSEARCH statement terminates the first search operation.
- CA Automation Point executes the second SEARCH operation (for the IEE612I message) in the same way.
Copyright © 2011 CA.
