The STOPREXX command stops an executing REXX program or cancels execution of a queued REXX program. The STOPREXX command can stop a REXX program only if the program is running within CA Automation Point.
Note: You must issue the GETREXXL command before issuing the STOPREXX command.
"STOPREXX rexxprognum"
Specifies the internal REXX pointer for a specific REXX program (acquired by a previously issued GETREXXL command).
Usage Note:
It is possible for the STOPREXX command to stop the issuing REXX program, meaning that your REXX program could terminate itself. Be sure that your REXX code allows for such a scenario when checking the GETREXXL_NAME.n variables generated by the GETREXXL command.
Example:
Suppose that you want to stop all instances of a particular program. Your REXX statements could look like these:
"GETREXXL" /* GETREXXL populates GETREXXL.0 with the number */ /* of active and queued REXX programs, the */ /* GETREXXL_NAME.i variables with the name and */ /* arguments of a program, and GETREXXL.i with the */ /* number used by STOPREXX to terminate the program*/ DO I = 1 TO GETREXXL.0 parse upper value GETREXXL_NAME.i with rxname. IF rxname = token THEN "STOPREXX "GETREXXL.I END
Copyright © 2011 CA.
