The LOADRULES command enables a new CA Automation Point rules file dynamically (while CA Automation Point is running). A dynamically enabled rules file always replaces the current rules file.
"LOADRULES FILE(rulesfilename) [REPLACE({YES|NO|CLEAN})]"
FILE
Specifies the name of the CA Automation Point rules file (rulesfilename) that you want to enable.
(Optional) Specifies the condition under which you want CA Automation Point to enable the new rules file. Valid REPLACE values are:
Loads, compiles, and enables the new rules file even if one or more rules in the new rules file contain syntax errors.
Loads and compiles the new rules file, but does not enable the file. Specify NO to check for syntax errors in a new rules file.
Loads, compiles, and enables the new rules file only if all rules in the file are free of syntax errors.
Default: YES
Example:
Suppose that you want to enable a new rules file after 8:00 p.m. (when the second shift starts at your data center). Your REXX program may contain statements like these:
IF ((TIME('H')>15) & (2ND_RULES_LOADED=FALSE)) THEN
DO
"LOADRULES FILE(2NDSHIFT.RUL)"
2ND_RULES_LOADED=TRUE
1ST_RULES_LOADED=FALSE
END
Copyright © 2011 CA.
