The GETSCRN command captures the screen image associated with a session and places information about that session in variables.
"GETSCRN SESSION(sessname) [SCREEN(YES|NO)] [PREFIX(prefix|LINE|NO)]"
Specifies the name of the session (sessname) from which you want to capture the screen image.
(Optional) Specifies whether to create the REXX variable SCREEN to store the character portion of the screen image. This operand has two options:
Creates the SCREEN variable.
Does not create the SCREEN variable. Specifying SCREEN(NO) saves memory if you do not intend to use the SCREEN variable.
Default: YES
(Optional) Creates a stem variable to store the lines of a screen image returned to CA Automation Point. CA Automation Point stores each line of the screen in a separate variable and numbers the variables consecutively (for example, LINE.1, LINE.2, and so on).
Note: The variable numbered 0 (for example, LINE.0) always contains the total number of elements in the stem variable.
Valid PREFIX values are:
The name that you want to assign to the variables set by the PREFIX operand. For example, specifying PREFIX(ROW) causes CA Automation Point to create stem variables named ROW.0, ROW.1, ROW.2, and so on through ROW.n.
Tells CA Automation Point to create REXX variables named LINE1 through LINEn to store lines of a screen image.
Does not create the screen variable. Specifying PREFIX(NO) saves memory if you do not intend to use the variables.
Default: LINE
Usage Notes:
Specifies the column in which the cursor is positioned.
Specifies the number of positions the cursor is away from the upper-left corner of the screen.
Specifies the row containing the cursor.
Specifies the operator information area (OIA) (also called the status line).
Creates a copy of the text of the screen image, with each row laid end to end. This copy does not include attributes such as colors or field positions.
Specifies the number of lines on the screen.
Specifies the number of characters the screen can contain.
Specifies the status of the screen:
LOCKED-The terminal emulator for the session is currently in an X-state and will not accept any input from the keyboard.
UNLOCKED-The terminal emulator for the session is not currently in an X-state.
Specifies the number of columns on the screen.
Examples--capture screen image:
"GETSCRN SESSION(S008)"
In the sample statement, S008 is the name of an MCS console session. Because this statement does not specify the PREFIX operand, CA Automation Point automatically stores lines of the returned screen image in REXX variables named LINE1 through LINEn.
The sample REXX program described next uses the CA Automation Point GETSCRN and WTO commands to capture the contents of a screen and place them in a file called SCREEN.cap. To invoke the REXX program, issue the command shown below either manually or using a CA Automation Point rule:
SC sessname filename [DEBUG]
The command has these components:
/* This REXX program captures a screen image. */ PARSE UPPER ARG . "'" TEXT "'" . /* Get the message text. */ IF DEBUG \= '' THEN TRACE R /* Activate REXX trace. */ PARSE UPPER ARG P1 P2 . /* Parse off positional arguments */ IF P1="" | P1='DEBUG' /* If first arg not there, */ THEN SESSNAME ='SESSION' /* Then set default session name */ ELSE SESSNAME = P1 /* Else, use 1st argument */ IF P2="" | P2="DEBUG" /* If second argument not there */ THEN FILENAME = 'SCREEN.CAP' /* Then set default filename */ ELSE FILENAME = P2 /* Else, use 2nd arg as filename */ 1 "WTO 'SC.CMD active, session= &SESSNAME filename= &FILENAME'" "GETSCRN SESSION(&SESSNAME) PREFIX(LINE) SCREEN(NO)" IF RC \= 0 THEN SAY 'GETSCRN FAILED, RC='RC ELSE DO TITLE = "SCREEN FROM SESSION " SESSNAME CALL LINEOUT FILENAME, TITLE DO I = 1 TO SCRLEN /* Loop through each row */ CALL LINEOUT FILENAME, LINE.I /* Write line to disk */ END CALL LINEOUT FILENAME /* Close the file */ END 2 "WTO 'SC.CMD COMPLETE' " EXIT
The WTO commands in SC.CMD issue write-to-operator messages as the GETSCRN command captures the screen image. The WTO command statement indicated by 1 in the example above alerts the operator when screen processing begins, and the statement indicated by 2 notifies the operator when SC.CMD finishes executing.
Copyright © 2011 CA.
