The ALARM keyword tells CA Automation Point to sound an audible alarm (a rising or rising-and-descending tone). By default, CA Automation Point sounds an alarm for all highlighted messages.
This keyword has the following format:
ALARM(alarmnumber)
Specifies alternate alarms. This value is a number from 1 to 20. If the number is 10 or less, the alarm consists of the specified number of rising tones. If the number is between 11 and 20, the alarm consists of a rising tone followed by a descending tone, repeated one to ten times depending on the number specified. For example, ALARM(20) sounds an alarm tone that rises and descends ten times.
You can use some of the alternate alarms for more serious problems so that they stand out. However, try not to use more than five different alarms because the differences between too many alarms are difficult to distinguish.
When you specify no alarmnumber value, you get a single beep, which is the standard alarm.
Usage Notes:
The ALARM facility is activated.
Example:
This message indicates that the WTO buffer is 80 percent full:
IEA405E WTO BUFFER SHORTAGE--80% FULL
The following rule alerts the operator to this problem using a tone that rises and descends five times:
MSGID(IEA405E), ALARM(15)
Copyright © 2011 CA.
