CA Automation Point Keywords › Keywords for Logging Messages › PRINT Keyword
PRINT Keyword
Specify the PRINT keyword to tell CA Automation Point to print a message to the hardcopy log.
This keyword has the following format:
PRINT
Usage Notes:
- To activate the hardcopy log, open the Message Logging Settings window in the Configuration Manager and enable the Print a Hardcopy Log of Console Messages option.
- If your workstation cannot communicate with the printer because the printer is not online, the workstation issues a message informing you of the problem. Paper jams and running out of paper are two common reasons that printers go offline. Do not specify the PRINT keyword unless an operator is nearby to oversee the printer.
Example:
The following message indicates that all SYS1.DUMP data sets are full:
IEA994E ALL SYS1.DUMP DATA SETS ARE FULL
The following rule writes message IEA994E to the hardcopy log:
MSGID(IEA994E), PRINT
Copyright © 2011 CA.
