The DISPLAY keyword causes CA Automation Point message recall windows to display a message that may have been previously suppressed with the SUPPRESS keyword.
This keyword has the following format:
DISPLAY
Usage Note:
The default color of the displayed message is white, but you can specify a different color with the COLOR keyword.
Example:
The following message shows the current spool usage and appears more frequently than necessary:
$HASP093 xx% SPOOL UTILIZATION
The following rules limit the number of times the operator sees this message by forcing the message to display at intervals at least ten minutes apart:
MSGID($HASP093), SUPPRESS MSGID($HASP093), EVERY(10 MINUTES), DISPLAY
Copyright © 2011 CA.
