The MSGID keyword defines the start of a message rule.
This keyword has the following format:
MSGID(characters)
Identifies a message that you want CA Automation Point to process. You can specify multiple messages by specifying the portion of the message ID that indicates a specific group of messages.
Usage Note:
CA Automation Point processes MSGID rule clauses in the following order:
MSGID(), MSGID(string), MSGID(*)
Examples:
MSGID(IRA201I), HILIGHT
AXC0901E Continued sendkey failures to session S008
The following rule dispatches a REXX procedure called CHKSESS to determine whether a workstation problem or a host problem generated message AXC0901E:
MSGID(AXC901E), EVERY(5 MINUTES), REXX(CHKSESS SESSION(&WORD7))
%%%%%%%%%% OPCOM 8-APR-1994 06:10:19.32 %%%%%%%%%% DEVICE $1$LPA0: (VAXD) IS OFFLINE
The following rule sounds an audible alarm when this message contains the text LP and OFFLINE:
MSGID(DEVICE),
WHEN(&WORD2(4:5) EQ 'LP' AND &WORD5 EQ OFFLINE),
ALARM(3)
Note: The rule shows DEVICE as the MSGID. When you write messages for OpenVMS sessions, the MSGID begins after the OPCOM header.
In this example, MSGID rule clauses are case-sensitive. For the message Please mount tape 1233, use the following:
MSGID(Please)
For the message PLEASE MOUNT TAPE 1233, use the following:
MSGID(PLEASE)
Copyright © 2011 CA.
