The EVERY keyword controls how often a rule executes again after it has executed the first time.
This keyword has the following format:
EVERY(n interval)
Indicates how often or at what time interval you want the action to be taken. You can specify any positive integer, but the value you specify cannot be a status variable.
Specifies the unit of time for the interval. This value can be any of the following:
Tells CA Automation Point to take the action every n seconds.
Tells CA Automation Point to take the action every n minutes.
Tells CA Automation Point to take the action every n hours. In this case, the n value can be any number from 0 through 23.
Example:
Suppose that the following message, which shows the current spool usage, appears more frequently than necessary:
$HASP093 xx% SPOOL UTILIZATION
The following rules cause this message to appear at intervals at least ten minutes apart:
MSGID($HASP093), SUPPRESS MSGID($HASP093), EVERY(10 MINUTES), DISPLAY
Copyright © 2011 CA.
