The SCAN parameter indicates the electronic location of the key.
This parameter has the following format:
SCAN=number [(shifts)]
Specifies the sequence number associated with a given key. This number changes depending on the physical layout of the keyboard (for example, 83-key keyboard, 101-key keyboard). If you do not use the utility program, look up this location in the reference manual for your keyboard.
(Optional) Indicates any shift states that must also be true for this operation. Possible shifts values are as follows:
Press the Shift key located on the right-hand side of the keyboard.
Press the Shift key located on the left-hand side of the keyboard.
Press either the left or right Shift key.
Indicates a lowercase letter (a through z).
Press the Caps Lock key. You must press the Caps Lock key twice-once for the operation and once to unlock the CAPS LOCK.
Press the right Shift key, the left Shift key, or the Caps Lock key. You must press the Caps Lock key twice-once for the operation and once to unlock the CAPS LOCK.
Press the Scroll Lock key. You must press the Scroll Lock key twice-once for the operation and once to unlock the SCROLL LOCK.
Press the Num Lock key. You must press the Num Lock key twice-once for the operation and once to unlock the NUM LOCK.
Press the control (Ctrl) key.
Press the alternate (Alt) key.
Indicates that whatever shift state is true, the operation is always mapped to the indicated key.
Examples:
SCAN=30(LOWER)
SCAN=30(UPPER)
Copyright © 2011 CA.
