The VER command provides the version number of the CA Automation Point interface to CA OPS/MVS on your workstation.
ADDRESS OPS 'VER [CMDRESP(destination)] [PREFIX(newvarname)]'
(Optional) Directs return information to a specific destination. For a description of valid destination values, see ADDRESS OPS Return Information in this chapter.
Default: REXX
(Optional) Directs return information to a stem variable name (newvarname) other than the default. For more information, see the section ADDRESS OPS Return Information.
Note: The PREFIX operand is valid only if the destination of the return information is REXX.
Default: OPS.VER
Return Information:
The VER command returns one line of information containing four fields. The fields contain the following information:
Field |
Description |
1 |
The name of the API (for example, OPS Rexx C API) |
2 |
The version number (for example, 11.3.0.0 Rev=99999) |
3 |
The Build date of the current CA OPS/MVS service in mmm dd yyyy format (for example, Jul 05 2010) |
The following is an example of a return information line:
OPS Rexx C API 11.3.0.0 Rev=99999 Jul 05 2010
For more information, see ADDRESS OPS Return Information in this chapter.
Copyright © 2011 CA.
