The LIST command returns a list of nodes that are currently configured on the issuing CA Automation Point workstation.
Note: This command should be used for diagnostic purposes only.
ADDRESS OPS "LIST [CMDRESP(destination)] [PREFIX(newvarname)] [SYSTEM(MSF system name|ALL)]"
(Optional) Directs return information to a specific destination (destination). For a description of valid destination values, see ADDRESS OPS Return Information in this chapter.
Default: REXX
(Optional) Directs return information to a stem variable name (newvarname) other than the default. For more information, see ADDRESS OPS Return Information in this chapter.
Note: The PREFIX operand is valid only if the destination of the return information is REXX.
Default: OPS.LIST
(Optional) Specifies the CA OPS/MVS node name that is defined in the Selected MSF nodes section of the CA‑OPS/MVS Event Traffic Configuration dialog. This name corresponds to the name used by the CA OPS/MVS Multi-System Facility (MSF) to identify itself to CAICCI. You can specify only one CA OPS/MVS system per LIST command.
Note: If this operand is specified, it acts as a filter and returns data only for the specific CA OPS/MVS host.
Default: ALL
Return Information:
The LIST command returns a line of information for each MSF system specified by the SYSTEM operand. Each line contains three fields of information, as described in the following table.
Field |
Description |
1 |
Specifies the name of the remote CA OPS/MVS node name that is defined by the MSF facility. |
2 |
Specifies the status of the CA Automation Point to CA OPS/MVS connection.
Note: If you specify a specific host on the SYSTEM operand, only a single line of output is generated for that host. |
3 |
Specifies the ENF/CCI system name used by CAICCI to identify the z/OS host. |
For more information, see the section ADDRESS OPS Return Information.
Copyright © 2011 CA.
