The SNMPTRAP command sends an SNMP trap to the specified host.
ADDRESS TNG "SNMPTRAP HOST({HostName|*}) [COMMUNITY(CommunityName)]
GTRAP(GenericTrapNum)
STRAP(SpecificTrapNum)
DATA(RexxVar)"
Specifies the TCP/IP host name (HostName) to which the event is to be sent or * for all host names specified for message forwarding in the Configuration Manager GUI.
(Optional) Specifies the community name (CommunityName) under which the trap is to be issued.
Default: public
Specifies the SNMP generic trap type (GenericTrapNum), which can be a value of 0 through 6.
Specifies the specific trap number (SpecificTrapNum) to be used when the enterprise-specific GenericTrapNum has a value of 6.
Specifies the data content of the SNMP trap, which is stored in a REXX variable (RexxVar). The REXX variable must contain the following:
rexxvar.0 = The total number of values supplied (this number must always be a multiple of 3; six are shown below) rexxvar.1 = OID 1 rexxvar.2 = type 1 rexxvar.3 = value 1 rexxvar.4 = OID 2 rexxvar.5 = type 2 rexxvar.6 = value 2
Specifies he SNMP object identifier for the trap.
Specifies the data type of the value that follows. type can be one of the following:
counter |
null |
opaque |
gauge |
objectidentifier |
opaqueascii |
integer |
octetstring |
timeticks |
ipaddress |
octetstringascii |
Specifies the value to be sent by the trap.
Copyright © 2011 CA.
