ADDRESS TNG Commands › ADDRESS TNG Command Syntax
Issue a command from within a REXX program by specifying an ADDRESS TNG statement, as shown:
ADDRESS TNG 'tngcommand operand(s)'
Follow these guidelines when issuing a command:
- When specifying a required or optional operand with a command, use parentheses to pass values. For example:
PROPERTY(propertyname)
- Do not name your variables with names reserved for ADDRESS TNG commands when creating REXX programs that issue TNG commands.
- Do not include the following characters when creating REXX programs that issue TNG commands,: ()'"<>|. REXX interprets them as REXX delimiters.
- Uppercase or lowercase characters are valid. For example, the following are both valid:
HOST(hostname) and HOST(HOSTNAME)
- Leading and trailing blanks are ignored. For example, the following are both valid:
HOST(hostname) and HOST ( hostname )
- Single and double quotes are valid. For example, the following are all valid:
COMMAND(commandstring) and COMMAND('commandstring') and COMMAND("commandstring")
- Operands shown in brackets ([ ]) are optional.
Copyright © 2011 CA.
