Previous Topic: SLEEP CommandNext Topic: VER Command
STARTREXX Command
The STARTREXX command executes another REXX program.
Note: You can also use this command to start any executable program on a local system.
ADDRESS VOX "STARTREXX PROGRAM(progname[arguments])"
PROGRAM
Specifies the name of the REXX program that you want to execute and the arguments to pass to the program, if any.
Return Information:
After the STARTREXX command executes, it sets the special REXX return code variable RC.
Example:
The following REXX code illustrates how to use the STARTREXX command in a program that processes incoming calls destined for the help desk. When CA Automation Point receives a call, the HDCTRL.CMD program starts a program named HELPDESK.cmd to service the call automatically.
/* HDCTRL.CMD */
signal on halt Name DoExit
do forever
   /* Wait forever for an incoming call and any channel within */
   /* the HELPDESK group. */
address vox answer group(helpdesk) hookstate(onhook) prefix(handle)'
if RC == 0 then
   do
      /* Call answered. Start the HELPDESK.CMD */
      /* program to service the call.          */
      address vox 'startrexx program(helpdesk.cmd 'handle')'
   end
end
DoExit:
/*Exit from the command shell so that CA Automation Point can "cleanup."*/
'@exit'
end
