The GETTAPIDEVICELIST command lists all the Telephony Application Programming Interface (TAPI) devices that are installed under Windows on the Notification Server.
ADDRESS VOX "GETTAPIDEVICELIST [PREFIX(varname)] [CMDRESP(destination)] [SYSTEM(sysname)]"
(Optional) Specifies the name of the REXX stem variable (other than the default name) that contains return information for the command.
For information about changing the default variable name, see ADDRESS VOX Return Information in this chapter.
Default: VOX.GETTAPIDEVICELIST
(Optional) Directs return information, if any, to a specific destination. For a list of valid destination values, see the ANSWER command.
Default: REXX
(Optional) Specifies the name of the system that is running the notification server to which you want to direct the command.
The sysname value can contain up to eight alphanumeric characters.
Default: The local system name.
Return Information:
After the GETTAPIDEVICELIST command executes, it sets the special REXX return code variable RC.
The information returned contains the device ID (in numeric form) and the modem description installed on that device ID. Each line of information is in the format n:desc where n is the device ID and desc is the modem description. The value stored in the VOX.GETTAPIDEVICELIST.0 variable represents the total number of TAPI devices.
For example:
0:U.S. Robotics 56K FAX EXT 1:Motorola V.3225
Note: You can write a REXX program to retrieve and parse this returned information. For coding techniques on how to do this, see the sample REXX program fragment under the PAGE command description.
The numeric value returned in the VOX.GETTAPIDEVICELIST.0 variable represents the number of lines of data retrieved. Each line of information is in the format described above, and one line is returned per modem installed on the notification server workstation.
Example:
The following example returns all the devices in a stem variable and issues a SAY statement:
/* Display available TAPI device on AP Notification server using GETTAPIDEVICELIST */
address VOX "GETTAPIDEVICELIST"
if rc = 0 then
do
if datatype (VOX.GETTAPIDEVICELIST.0) = "NUM" then
do
do i = 1 to VOX.GETTAPIDEVICELIST.0
say VOX.GETTAPIDEVICELIST.i
end
end
end
else
do
say vox.error
end
return
Copyright © 2011 CA.
