The SETGROUP command associates a group name with one or more voice channels, enabling you to control the available channels more easily. The number of channels that you can associate with a single group is limited only by the number of lines that are installed at your site.
ADDRESS VOX "SETGROUP VAR(varname) [SYSTEM(sysname)]"
A stem variable name that you assign that contains the group definition information.
Specifies the related variables contain the following information:
The number of groups to define.
Formatted information for the first group name that you are defining. Each field contains specific information about the first group.
Formatted information for the second group name that you are defining, if applicable. Each field contains specific information about the second group.
Formatted information for the nth group name that you are defining, if applicable. Each field contains specific information about the nth group.
(Optional) Specifies the name of the system that is running the notification server to which you want to direct the command.
The sysname value can contain up to eight alphanumeric characters.
Default: The local system name.
Copyright © 2011 CA.
