The PURGE command deletes all volatile variables within a specified variable group. (The PURGE command has no effect on nonvolatile variables.)
ADDRESS GLV '[SELECT vargroup] PURGE'
(Optional) Specifies the name of a variable group (vargroup) to which the specified variable (varname) belongs.
For more information, see the description of the SELECT command.
If you do not select a variable group, the PURGE command erases all volatile variables in the group selected by the previously issued SELECT command. If you have not yet selected a group, the PURGE command erases all volatile variables in the UNNAMED group.
Examples:
ADDRESS GLV 'SELECT RELAYGRP PURGE'
ADDRESS GLV 'PURGE'
Copyright © 2011 CA.
