The following list summarizes CA Automation Point ADDRESS GLV commands.
Retrieves the current value of a status or GLV variable and assigns that value to a local REXX variable of the same name.
Places a list of all variable groups into the external data queue.
Places a list of all variable groups directly into a REXX variable.
Places the name and value of a variable into the external data queue.
Places the name and value of a variable directly into the REXX variable.
Deletes all volatile variables in a specified variable group.
Assigns the value of a local REXX variable to a volatile status or GLV variable of the same name.
Assigns the value of a local REXX variable to a nonvolatile status or GLV variable of the same name. (This command creates or updates a .GLV file.)
Selects a particular variable group for succeeding GLV commands to act upon. This command is valid globally as a stand-alone command or locally as an operand in most other GLV commands.
Assigns values to one or more volatile variables.
Assigns a literal value, which can contain blanks, to a single volatile variable.
Assigns a literal value, which can contain blanks, to a single nonvolatile variable. (This command creates or updates a .GLV file.)
Assigns values to one or more nonvolatile variables. (This command creates or updates a .GLV file.)
Provides the version number and maintenance level of GLV services on your workstation to the external data queue.
Provides the version number and maintenance level of GLV services on your workstation into a REXX variable.
Copyright © 2011 CA.
